Lenovo h520s case change to Cooler master elite 430 Front panel connection on motherboard?
KieranDavidW123
532
Hi
I'm going to change my lenovo h520s case to a bigger one as i need to if i want to fit a bigger psu and gpu.
Here is the link to my PC: http://www.pcmag.com/article2/0,2817,2410888,00.asp
And here is the link to my Hardware Maintenance: http://download.lenovo.com/consumer/desktop_pub/ideacentre_h520s_hmm_20120627.pdf
I have studied and know how to fit everything else in.
But my main problem is I don't know where the front panel connections go.
My motherboard has some sort of all in one connector and the front panel pins add up to 14 pins but the last 14th one is missing (I'm not concerned about that):
https://dub123.mail.live.com/att/GetAttachment.aspx?tnail=0&messageId=33e836d1-b425-11e2-a439-00215ad6e840&Aux=44|0|8D016491B6EA660||0|0|0|0||&cid=9c7db8843c3aa307&maxwidth=220&maxheight=160&size=Att&blob=MHxJTUctMjAxMzA1MDMtMDA5NDYuanBnfGltYWdlL2pwZWc_3d
I would really like to know where the hard drive activity light, power indicator, reset switch and power switch go.
Please reply ASAP
Thanks
You need to take a look at the original harness (usually 1 piece) on the old case and figure it out. Take a look at the dongle of wire that comes with the old case, and for each set of wire that comes out, which serves 1 function (1 LED or switch), trace it to where it connects to (position on the harness connector) and write it down (on paper with a diagram). Then you need to connect the new case connectors to the same positions that serves the same functions.
On the hardware maintenance PDF you linked to, on page 25, connector 11 is the connector you need to decipher based on the wiring harness that came with the old case.
LEDs are polarized, so if you connect them one way they don't light up, try swapping the position of the 2 wires (flip the connector).
Take a look at that photo i linked you to, I need to know what kind of front panel pinout my mother has, is it J18, JFP??
Please reply ASAP
Thanks
Your photo-link doesn't work. It appears to be a link to your inbox, which I can't access. Your pin-out is proprietary to Lenovo. You just need to decipher it by looking at the matching (mating) harness that came with the Lenovo 520 case. Look at that harness, and figure out the pin configuration by tracing each function to a set of pins, and write down a diagram.
