Hello, I've got a Lenovo ThinkPad L490 Laptop and last time I used it, it was working just fine. I turned it off and didn't use it for about a week.
I tried turning it on today but it won't power on even though the power-button's LED light and the light on the back of the screen stay on, the screen is all black and I've noticed the fan is not spinning up either.
While the power button light stays on, the caps lock key lights up just for about a second, then goes off and it just stays like that. If I try holding the power button to force shut it down, it goes off for a second and immediately comes back on.
I read there should be some reset pinhole on the bottom or the sides but I don't see one ?
Things I've tried:
What's weird is that after the last try where I tried unplugging the keyboard, pressing the power button while the charger is unplugged it no longer keeps the light on, it only stays on when the charger is plugged in, I think I may have messed it up even more now.
At this point is there anything else one could try or should I send it to a technician?
Things I've tried:
- Took off the back cover and disconnected the battery, then held the power button for 20-30 seconds.
- Reseated the RAM stick on both slots (it's just one stick).
- Unplugged the CMOS battery and left it like that for about 10 minutes.
- Unplugged the keyboard in case it was causing some issues but still nothing.
