These batteries were never hot-swappable: had you tried that, you'd have stone cold lost any work in progress.
You'd have to hibernate or shutdown, not even a suspend to RAM would have likely survived the time it took to swap those batteries.
Were they usefull? Were they worth the extra mechanics, form factor compromises?
Since batteries have limited life-times and deteriorate, having the ability to replace them, seemed to make sense. Except that those removable ones disappeared even faster from vendor support shops than the so-called "non-removable" units that came later.
Those were often so generic, you could get them from someone, somehow much later. And sometimes, those wouldn't even blow up.
But then there were always notebooks that would just eat batteries alive, original ones and replacements, and others, where the original battery seemed fine even after a decade of (admittedly moderate) use.
I cannot associate batteries with any type of nostalgia. They were a source of worry, trouble, concern, cost and anger from the very start.
Sure, without them portables would have remained portables and never operated without external power.
But boy, did they ever make you pay for the privilege!
Batteries suck! But needing external power sucks even more!
