lenovot510work fine on battery after unplug but won't turn the power on
Sony_1
Commendable
Sep 15, 2016
if I unplug the power code from Lenovo t510 ,work fine until I turn off the computer. but won 't turn on battery only if I plug in the power code.
Well it could be a few things.
1. Your battery could need replacing.
2. Your cord could be damaged, although still functioning to run the laptop alone. This is very common. When a charger cord goes but only partially. It will power the device, but not power it and charge the battery at the same time. It will also usually charge the battery when the laptop is turned off (not hibernate or sleep, but off).
3. A combo of both things above. The battery needing replacing and the cord as well.
