Hey. Recently upgraded my motherboard to a MSI Z170A Tomahawk. I was using SpeedFan to controll my fans on my previous motherboard, with all fans 3 connected to 1 pin. I installed msi's Command Center this time (which previously wouldn't work). I can here when setting up the fans that it does go up and down in speed, put I'm unable to have the speed graph go under 50%, making my system very loud. I have seen videos where you can edit a text document and make it low, but this makes the point under the visible diagram.
Is there a way I can have it visibly at 0% and let me edit the area below 50%? or atleast make a text document with all the points writen down?
Thanks in advance!
Thanks in advance!
