Hi all,
I bought a Lexar 16GB usb flash drive (the back says: "LJDV10-16gb-000-111af 34014-16gbna 43138" I'm not sure which parts are the product code so thats all of it just in case)
Plugged it into my late 2012 13" Retina MBP running 10.9.2, and nothing. There is a red light on the USB which flashes red three times when plugged in then just glows in and out.
Doesn't show up in Disk Utility at all. So I googled around for a while and some people had the same problem however I couldn't find a definitive answer/solution anywhere.
Next I tried System Information, and got somewhere! This is the exact tree:
USB Hi-Speed Bus:
Host Controller Location: Built-in USB
Host Controller Driver: AppleUSBEHCI
PCI Device ID: 0x1e2d
PCI Revision ID: 0x0004
PCI Vendor ID: 0x8086
Bus Number: 0x1a
Hub:
Product ID: 0x0024
Vendor ID: 0x8087 (Intel Corporation)
Version: 0.00
Speed: Up to 480 Mb/sec
Location ID: 0x1a100000 / 2
Current Available (mA): 500
Current Required (mA): 0
USB Flash Drive:
Product ID: 0xa81d
Vendor ID: 0x05dc (Lexar Media, Inc.)
Version: 11.00
Manufacturer: Lexar
Location ID: 0x1a120000 / 4
Current Required (mA): 200
So it appears my mac sees something but won't display it?
I've tried DiskWarrior, but it couldn't find the drive.
I plugged the usb drive into a windows computer and the loading bar came up and said it was installing the device or something like that however when it was complete the drive didn't show up anywhere except Disk Manager. However in Disk Manager it shows there is something in D: but has 0bytes free and "no media". I assigned it a new letter but same result. I also couldn't format the drive, or anything like that. I played around with the driver settings, update, reinstall, etc, but no luck.
I reset my SMC and NVRAM and still nothing.
So this is where I'm at right now, I hope I've provided enough information.
Any ideas?
USB Hi-Speed Bus:
Bus Number: 0x1a
Hub:
Product ID: 0x0024
Version: 0.00
USB Flash Drive:
Product ID: 0xa81d
Version: 11.00
Manufacturer: Lexar
Any ideas?
