LF 27"+ monitor purchasing help
Tweakster
44
Want to purchase a new monitor during online deals for black Friday and was hoping you guys have some suggestions.
Currently running NVidia 560ti- likely will upgrade to something better within the year
Looking for a 27in monitor, high resolution looking for 120mHz+
Using it for gaming and amateur graphics design, able to handle 3d and regular blueray movies
Any suggestions or leads to great deals.
Thanks
Tweakster
44
-Lone-
Admirable
Nov 5, 2014
3,489
380
Well, that depends on what your computer specs are, you will need more computer power if you want higher.
Tweakster
44
CAS: * In-Win Dragon Rider Full Tower Case w/ 1x120mm Front Fan, 1x220mm LED Side Fan, Front USB 3.0 x 2 & Water-Cooling Hole Ready (Black Color)
CD: Sony 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
COOLANT: Standard Coolant
CPU: Intel(R) Core™ i7-2600K 3.40 GHz 8M Intel Smart Cache LGA1155 (All Venom OC Certified)
CS_FAN: Default case fans
FAN: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Dual Enermax Enlobal Silent High Performance 120MM Fans (Push-Pull)
FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOR)
HDD: 120 GB OCZ Agility 3 SATA-III 6.0Gb/s SSD - 525MB/s Read & 500MB/s Write (Single Hard Drive)
IUSB: Built-in USB 2.0 Ports
MEMORY: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory Module (Corsair or Major Brand)
MOTHERBOARD: * [CrossFireX/SLI] GigaByte GA-Z68X-UD4-B3 Intel Z68 Chipset DDR3 ATX Mainboard w/ Intel Smart Response Technology & 7.1 Dolby Home Theater Audio, GbLAN, USB3.0, 4x SATA-III RAID, 2 Gen2 PCIe, 2 PCIe X1 & 2 PCI (All Venom OC Certified)
OS: Microsoft(R) Windows 7 Home Premium (64-bit Edition)
OVERCLOCK: Extreme OC (Extreme Overclock 20% or more)
POWERSUPPLY: 850 Watts - Corsair CMPSU-850TXV2 80 Plus Power Supply - Quad SLI Ready
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: NVIDIA GeForce GTX 560 Ti 1GB 16X PCIe Video Card (EVGA Superclocked
Also trying to upgrade system if the upgrade is worth doing.
-Lone-
Admirable
Nov 5, 2014
3,489
380
I think you may have to upgrade your GPU, 1GB of video memory may not be enough for higher resolutions.
Tweakster
44
thx 4 the input
Similar threads
