Hello,
I'm working on a build using - SilverStone SG05W LITE
There is a super slim drive slot, in which i would like to install Fan Controller. But i cant seem to find any in this size?
Other thing i need is a 120 fan, with lights that work even if the fan will be set to 0.
Now the build is:
Asrock Fatal1ty B450 ITX
Athlon 200GE & Alpine AM4 Passive
Crucial MX500 1TB M.2
Corsair DIMM 16 GB DDR4-3000 Kit
Enermax Revolution 550W SFX, PC-Netzteil
1050Ti KalmX
And i wonder, can i remove fan from PSU? Since the build will use 300W at most.
Can i use spray paint on the CPU radiator?
How much of a difference there is beetwen 200GE and 2200G or 1600 when it comes to normal work?
I saw people suggesting going for bdie memmory with Ryzen, does it make a difference?
Any sugestions, much apreciated!
Now the build is:
1050Ti KalmX
