[SOLVED] Lg 22mp68vq audio ?
Simran Jeet
150
Hey guys im using a lg 22mp68vq connected via hdmi to my gpu (gtx 1060), it has a 3.5 mm audio jack at the back so i was wondering if it is sourcing audio straight from the gpu to audio jack or if it is processing it and if it is processing will it be of good quality ? And is hdmi audio good ?
Pc specs
Processor - i5 6500
Mobo - gigabyte h110m s2
Ram - hyperx 2133 8gb single
Gpu - palit gtx 1060 6gb
Ssd/hdd - samsung 750 evo 120gb/ wd blue 1tb
Psu - corsair vs 450
Case - corsair 100r
Monitor - lg 22mp68vq
The audio would be sourced off the GPU's HDMI port. The HDMI port has both audio and video, same goes for DisplayPort. You should try out the sources of your audio before settling on which is better for you.
I would highly recommend you change the PSU on that system.
