LG 24EA53VQ 24 inch IPS LED monitor
tfqindia
Hi All,
I recently got myself a LG 24 inch IPS monitor, when I switched it on I was not much satisfied at the first look, there is this light leakage most of them complaining about + movies or videos are not much bright, colors are good, but brightness is bad. I'm not sure if this will change if I upgrade my system, I currently run the below configuration
Dual Core 2.8GHz
RAM 512MB DDR
Intel extreme graphics 2
Windows XP service pack 2
Any suggestions or views would be helpful.
Thanks in advance.
Hi,
Thanks for you reply, I did find that the pictures were not good to watch on the new monitor even though the brightness was set to maximum, but then I found out that changing brightness of the intel graphics display adapter did fix the issue, + lowering the response time did make the video smooth and better.
