LG FLATRON W2243S resolution problem
Spookas
4
Hello, I got this monitor for a while now, and I'm stuck with 1680x1050 resolution. I want It's native resolution (1920x1080). First when I switch to 1920x1080 I get my view cut off, here's a picture showing that:
http://imgur.com/InLTUuW
Second, my system thinks that my native resolution should be 1680x1050.
Additional information: GPU: MSI GT 630 with the newest BETA drivers installed. The monitor's drivers are installed and It's connected via VGA cable. I don't get why, but I can use 1920x1080 resolution while playing games.
If you need some more info - just ask. :)
So yeah, what's the problem? Would like to have this solved quickly, because I've been living with this for too long...
Seems like that monitor only has a VGA connection, is that the case? If not, try the other connection. I'd also test it with a second computer.
What is the refresh rate set to? Did you try to do a reset on the monitor and also use the auto config option?
Thanks for the reply, but fixed it with Nvidia Control Panel's timing options. Played with the preset settings and it works like a charm. :)
Latest posts
