LG G3 won't turn on, failed battery?
Adam1998
95
I left my phone on change over night and woke up to it being unresponsive. I can't turn the device on anymore. Could this be a battery issue? I know there are several forums with answers online, but I have some specific information that makes me believe this could be a failed battery.
To begin with, I've had battery issues before, an issue where the phone would not change. This has since resovled itself overnight. Another thing to note is that plugging the phone into a charger without the battery had the phone come on telling me to insert the battery. This shows there is some life in the phone itself. Finally, when I have the battery in the led light does not appear when the charger is in, which seems to show there is no connection. However, as mentioned before the phone detects the charger without the battery so it's not that.
Do these sound like the symptoms of a failed battery?
G3 has a removable battery, easy to test if it's the battery, replace it see if it works. Probably first thing to try here. You can get a new battery for under $10 on ebay for the phone.
Hello,
It really sounds like a battery problem. Merely go try this G3 battery on another mobile phone to see whether it could works well there. If not, go select a new one according to your own conditions.
