A Arion Denis Reputable Jul 17, 2014 3 0 4,510 May 3, 2015 #1 Hello everyone, could someone tell me if it is posible to remove the support (the bottom thing which is holding the monitor) of the LG Led 22M45 monitor and how ? I have one and have no ideea how to do so... Thank you.
Solution Phillip Corcoran May 3, 2015 Download the manual via the link on this page: http://www.lg.com/us/support-product/lg-22M45D-B Open manual with Adobe Reader. From the page index panel on the left, click on "Detaching the Stand Base". You might find it easier to read and follow if you print off that page (page 5) on to an A4 sheet.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,104 912 120,140 May 3, 2015 Solution #2 Download the manual via the link on this page: http://www.lg.com/us/support-product/lg-22M45D-B Open manual with Adobe Reader. From the page index panel on the left, click on "Detaching the Stand Base". You might find it easier to read and follow if you print off that page (page 5) on to an A4 sheet. Upvote 0 Downvote Solution
P Pixma4 Commendable Nov 24, 2016 1 0 1,510 Nov 24, 2016 #3 I hope you will get your solution clearly at the last comment here.. https://www.neowin.net/forum/topic/1314534-how-to-removedetach-stand-of-lg-led-monitor/?do=findComment&comment=597679908 Thank you. Upvote 0 Downvote
