Question LG Monitor D2343 Stuck In Power Save Mode
Ryguy99
Commendable
Mar 29, 2017
Good day Forum.
For some reason my secondary monitor, an LG D2343 (CINEMA 3D 24") is stuck in power saving mode.
Here is a list of fixes I have tried:
1 Restarted PC
2 Removed Monitor power cable and re inserted (Whilst tapping the power button to drain excess power)
3 Tried Different cables (HDMI & DVI-D)
4 Tried my other monitor on the DVI-D Out on the GPU, Main monitor works just fine
5 Powered both the PC & Monitor down, disconnected from power, drained residual power and restarted.
6 Checked to see if all components were properly connected - Removed & Replaced RAM
7 Uninstalled Graphics Drivers and Reinstalled
8 Removed what little dust there was in the fans
9 Made sure the MB Battery was properly seated
10 Left all components off for 30 minutes
EDIT: Tried a different GPU - Screen worked for a few seconds, although the resolution was 1078 x 400? Very confused.*
Setup
Operating System
Windows 10 Enterprise 64-bit
CPU
Intel Core i5 4670 @ 3.40GHz 43 °C
Haswell 22nm Technology
RAM
8.00GB Dual-Channel DDR3 @ 801MHz (11-11-11-28)
Motherboard
ASUSTeK COMPUTER INC. Z87-PRO (SOCKET 1150) 26 °C
Graphics
4096MB ATI AMD Radeon R9 200 Series (Sapphire/PCPartner)
