LGA 1150 Replacement Lockdown Screws! HELP!!
raklyiz
Recieved a 1150 z97 board from a buddy of mine, but the board is missing the torx screws for the LGA 1150 CPU lockdown bracket.
Does anyone know where I can get replacements? Went to local shops no one could help =\
According to this: http://www.intel.com/content/dam/www/public/us/en/documents/guides/4th-gen-core-lga1150-socket-guide.pdf
The two top screws are standard 6-32 T20 screws, which you should be able to find in any hardware store (the shape of the head doesn't really matter, you might want to use Philips instead of Torx as those are much harder to find).
The bottom one is trickier (see figure 8, p.19 of the PDF), I don't think you'll be able to find it anywhere.
Your best option would be to contact the motherboard manufacturer and ask to purchase replacement screws.
