I purchased a Lian Li http://www.newegg.com/Product/Product.aspx?Item=N82E16811112130 case that I really like the looks of. I bundled this with a PowerTek 770W ATX PSU.
Plans has been to build a Quad PC with maybe a 8800 GTS video card (around a $1000 left to spend) with the intent of doing a conservative OC on the CPU and RAM.
Problem is, a friend pointed me to the Newegg.com reviews on this case to back up his belief that this case will never be able to handle the heat from a Quad or an 8800 GTS or better card.
Did I waste my money or is this build still salvageable?
Also I would appreciate any advice on what type of Quad / Mobo / Ram that would fit this size case, if possible, without heat problems.
BTW I did find a PCI Slot fan and wondered if that would help.
Any help would be appreciated.
