Question Lian Li DK07 Desk Case: Fan configuration in an air-cooled single-system build ?
Mar 20, 2025
28
I am about to start an air-cooled build in a Lian Li DK07 Desk Case. My component list is below. Nothing will be overclocked.
The case's fan configuration seems to lend itself to having many intake fans but only one exhaust fan, which doesn't seem optimal. Furthermore, the case has no top fans.
I am willing to put the motherboard in any of the three possible locations: center (standard location for a single system build), left, or right.
Can I get some thoughts or suggestions for fan configurations?
Thanks in advance!!
Case: Lian Li DK07
Case Fans: Noctua NF-A12 and NF-A14 PWM
PSU: be quiet! Dark Power Pro 13 1300W
Mother Board: ASUS ROG STRIX X870E-E GAMING WIFI
CPU: AMD Ryzen 9 9950 x3d
CPU Cooler: Noctua DH15 G2 LBC
CPU Cooler Interface: Thermal Grizzly KryoSheet (33x33x0.2mm) Graphene Pad
RAM: Corsair Vengeance DDR5 96GB (48GB x 2) 6000MHz CL30 (for AMD)
Graphics Card: ASUS (NVIDIA) Astral GeForce RTX 5080
SSD: Crucial T705 (2024) 4TB PCIe Gen5 NVMe M.2
Center MB Position
It appears that you might need to install the 11 fans in a left to right cross flow direction; 5 intake fans on the left and 6 exhaust fans on the back and right. Alternately if you're not using the front vents for anything you could mount 6 intake fans there and use the bottom and back as an exhaust.
Reactions: Small_Town_Gamer
