Question Lian Li Galahad 240 not cooling Cpu
Feb 5, 2025
13
Hello,
Last night my partners CPU started to overheat and restart her pc. I did some troubleshooting and realized the pump was no longer reading rpms and duplicated results on a different pwm header
Luckily I had a spare aio I hadn't used. Threw it in there and it instantly fixed the no rpm data issue however the CPU was still getting too hot and maxing our temps. I repasted the cooler made sure everything was mounted down tightly but no changes. I checked the manufacturer info and might have figured out the issue but am looking for advice.
I've mounted it with the hardware I believed was correct (see below)
However in the installation video for lga1200 socket it showed different mounting hardware (see below)
But I don't think I have this hardware anymore! Is there somewhere I could get replacements? Could this be the cause of my issue? Any advice would be appreciated
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your partner's build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Lian Li Galahad 240
Lian-0Li have a number of AIO's under the Galahad series, which one do you have? You're also mentioned using a spare AIO...you need to understand that due to permeation, fluid's can evaporate an AIO over time. How old is the spare/replacement AIO? What is the make and model of the spare AIO you're working with?
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Lian Li Galahad 240
CPU: Intel 10th Generation i7 10700 kf
CPU cooler: Lian Li Galahad 240 V1 (link provided to model)
Motherboard: Asus Tuf gaming z590 plus
Ram: 32 Gb 3200 mhz corsair
SSD/HDD: nvme ssd
GPU: rtx 3070
PSU: (currently unknown can fill later
Chassis:Thermaltake case
OS: Window 11
Monitor: currently unknown can fill later
The galahad cooler I have is the original 240mm. It's about 2 years old (since I got it) but been in storage and not used. Link provided above to model
