Question Lian li hydroshift fans question
redbeardkevv916
Commendable
Apr 13, 2022
14
I plan to use this aio but I also have 11 artic p12 pwm fans and I want to use 3 of them them on this aio . How do I configure it to work ? Thank you
you would remove the included preinstalled fans,
screw in your existing fans,
run your fans through a hub, or any included cable grouping option that will then allow your fans to be daisy-chained, and run them to the motherboard's CPU_FAN header.
but as @Lutfij mentioned,
the included Lian Li fans are much better for this use.
why do you want to swap them out?
Reactions: Lutfij
Why spend more on fans to make them match when I have these
you won't be spending anything because the Lian Li fans are included with the AIO.
the point is that those included Lian Li fans are much higher quality and are actually designed for the high pressure scenario of being radiator fans.
unlike your Arctic case fans which are just decent mid-level airflow / low-level air pressure fans.
if you want to sacrifice good performance for some not-even-noticeable aesthetic, go ahead with them.
just seems kind of stupid to've spent more on a higher quality cooler just to then alter it's actual performance to a lower standard with lower quality components.
