Question Lian Li Lancool 2 Mesh Performance vs RBG question
alexbeast
155
So basically my case isn't cutting it for airflow and I also don't have enough room to front mount my MSI 240r(for optimal results it needs to be front mounted) so I need to get a better case. Ive decided to choose the lancool 2 but im debating to get the RGB or performance version. Both cases I can mount the 240r for intake but the performance version does have 140mm fans. I did want to make an RGB rig however so the extra RBG fans would be nice but at this point I just want my temps to be good. I was also thinking about getting the performance + getting a 280mm radiator for the best results but that would mean I bought the 240r for nothing. opinions would be appreciated and do you guys think I should just go with the 280mm + performance and hopefully sell off the 240r (its brand new) or just install the 240r on either the RBG or performance?.
DEEPCOOL MATREXX 50
CORSAIR RMx Series RM850x
RTX 3080
MAG Core Liquid 240R
AMD Ryzen 7 5800X
ASUS ROG Strix B550-A
G.SKILL Trident Z Neo 32 gb
SAMSUNG 980 M.2 NVMe 1tb
