[SOLVED] Lian Li lancool ii mesh for my build
Bob1nba
195
12
4,585
I'm putting together a new build and ive been looking into cases and im strongly considering using the Lian Li lancool ii mesh because it has great reviews and good thermal potential, for a solid price as well.
My only question is I planned on using a Nzxt x63 kraken 360mm aio, does this case allow for this to be mounted on the front of the case and used as intake? I than planned to use the two fans that come with the case in the front and put them on the top as exhaust. Im kind of new to this whole intake/exhaust and aio cooling so I just want ideas on how I should go about doing it best in this case.
I'm also open to other case ideas if anyone has other good options.
D
My other question i guess would be is the case says it doesn't come with a USB c port in the front but you can buy an adapter if needed. I honestly don't know if I would even need that or not, what devices benefit from using that?
This is the case I went with... Fractal Design Meshify 2
It's very roomy with support for 360/420mm radiators. It also has a USB C port in the front. I use the port for transferring data from my drone, iPhone/iPad, and also use it with my VR headsets.
View: https://youtu.be/qTW2KHGzbM0
It made their best of 2020 list and won best mechanical design.
Yes it would fit,
View: https://youtu.be/dhf97n0eqx4
I have my 360mm Z73 AIO mounted up top blowing out... 1 rear 140mm blowing out... 3 front 140mm blowing in... 1 bottom 140mm blowing in.
Good luck!
