Hi Sifus and Master Gurus,
I will be building my new rig within these 2 months, so I would like to enquire on what kind of layouts is optimum for the following parts.
I have also attached a few simple pictures on my proposing layouts (Please choose the most optimum for Budget Air Cool and Full Water Cool), fans can be added at any amount if needed from the list.
The back of the case should be all same for Air/Water as per picture.
Red Arrows => Components
Yellow Arrows => Water Flow Direction Proposal
I would probably used 1 of the Budget Air Cool builds first, and then upgrade to the Full Water Cool layouts when I'm planning to buy a RTX 5080/5080 Super in the future (Mod to full water block).
Used Tumblr as a link for the pics
Part Number / Description | Qty | Remarks | |
Computer Case | Lian Li O11 Dynamic Evo RGB — White (Mid-Tower) | 1 | |
Case Optional Accessories | Lian Li O11 Dynamic Evo RGB Additional I/O Kit — White | 1 | |
Lian Li O11 Dynamic Evo RGB PCIE 4.0 Upright GPU Bracket Kit — White | 1 | ||
Lian Li O11 Dynamic Evo RGB 4 - Slots Vertical GPU Kit — White | 1 | ||
Processor | AMD Ryzen 7 7800X3D | 1 | |
Motherboard | Asrock X670E Taichi Carrara | 1 | |
RAM | Corsair Vengeance 64GB ( 32GBx2 ) DDR5 6000mhz RGB CL36 | 1 | |
Power Supply | Asus ROG Loki SFX-L 1000W Platinum | 1 | |
Graphic Card | Gigabyte GeForce RTX™ 2070 GAMING OC 8G — White | 1 | Old Transfer |
CPU AIO | NZXT Kraken 360 RGB — White | 1 | |
RGB Fans | Lian Li Uni Fan SL Infinity 120MM ARGB Fan - White (3-Pack with Controller) | 1 | |
Lian Li Uni Fan SL Infinity 120MM ARGB Fan (Reverse) — White | 3 | ||
Lian Li Uni Fan SL Infinity 120MM ARGB Fan— White | 1 | ||
RGB Cables | Lian li Strimer Plus V2 24-PIN | 1 | |
Lian li Strimer Plus V2 8-PIN | 1 | ||
NVME SSD | Western Digital Black SN850X NVMe 4.0 (1 TB) | 1 | Old Transfer |
Adata XPG Gammix S70 Pro (2 TB) | 1 | Old Transfer | |
2.5 Inch Sata SSD | Samsung 860 Evo (500 GB) | 1 | Old Transfer |
3.5 Inch Hard Disk Drive | Western Digital Black (2 TB) | 1 | Old Transfer |
Western Digital Blue (4 TB) | 1 | Old Transfer | |
