Hello, thinking of building Lian Li PC-TU150 ITX system, Specs:
CPU: Intel i9 9900K
HSF: Noctua NH-U14S
M/B: Gigabyte Z390I Aorus Pro
RAM: 32GB G.Skill Trident Royal 3600
GPU: on-board or used ~GTX1060/1070 for now
SSD: 1TB Samsung 970 EVO Plus or 1TB Team Cardea Zero Z440(gen 4)
Case: Lian Li PC-TU150 TG Silver
PSU: Corsair SF750
Case Fan: just one exhaust 120mm fan, but not sure which one yet.
I picked Noctua NH-U14S cos it should just fit(height wise) and still offer enough room to install everything(i.e. mainly motherboard) without too much problem(i think).. but now I'm having second thoughts, and maybe go for be quite! Dark Rock Pro 4 since it's the heatsink used on TU150 product page.
so hopefully I can install it without too much difficulty(although I doubt that's gonna be the case cos it looks like a very tight fit).. and another advantage of U14S might be you should be able to see Royal RAM and LED/RGB exhaust fan much easier.
Has anyone used a large heatsink like D14/D15 or Dark Rock Pro 4 on TU150? did you have much trouble installing everything?
I'm not sure about the case color(black or silver) is well, I heard silver is much better(for fingerprints marks) but I still think black might look better overall?
Also any recommendation on case fan(planning to only use one exhaust fan) would be appreciated.. i.e. brand/model or color etc, thank you.
CPU: Intel i9 9900K
HSF: Noctua NH-U14S
PSU: Corsair SF750
