What would be the best way to get some more cooling on this case? I love the case but it just seems lackluster in the cooling department, especially for the price. I was figuring I could use a 140mm circular drill bit and drill fan holes in the top and then put some 140mm fans in after cleaning up the holes a bit. However, does anyone know of an easier way to get more cooling and fans in this case? Maybe something with those side mesh grills? Is there a bracket or something that can just be screwed onto the side somehow.
I'm trying to look for something that will do the job and be fun to do but not look ridiculous. So far, my only idea has been drilling 140mm holes, sanding the holes to be not sharp and to look nice, and then to put 140mm fans in with some custom grills from frozencpu or something. However, I'm not even sure if the aluminum on the top of the case would handle the force of the drilling.
Any suggestions?
Here is a link if you're interested: http://www.newegg.com/Product/Product.aspx?Item=N82E16811112476
Any suggestions?
