[SOLVED] lian li strimmer plus plugged into corsair hubs?
Nov 29, 2020
36
I just ordered lian li strimmer plus 24+8 pin, comes with a hub, curious if I can plug my rgb strip from o11 xl case to the hub
also hear you can plug in strimmers to corsair, do I have to have that ebay cable from piratedog?
https://www.ebay.com/itm/Corsair-RG...713804?hash=item56f1d8f04c:g:A90AAOSwzUdf-9PX
there's a description showing what it can and can't do.
i can't connect this to my commander pro LED spot. Sooo I'm using commander pro + 2 x cores, so thats 12 slots for fans. i'm using 10 of them. you're not suppose to mix different fans or led's on the same commander core right?
so how would I go about connecting my lian li strimmer 24 + 8 pin + rgb strip on my o11?
