Lian Li's PC-09 Combines Two Chassis In One
  • Thread starter Thread starter Guest
  • Start date Start date
Misleading title, it's not 2 chassis in one, it's 2 half-chassis in one - like the Corsair Air series.
On a side note, it'll be interesting to see how cooling works here. Looks to be extremely negative pressure, with no filters at least on the back (looks to be a filter on top?)
When the price of your case approaches that of a Case Labs case... you should rethink the price of your case. Unless someone truly prefers the aesthetic of this case, there is no intelligent reason you wouldn't buy a CL for the same money.
The fan placement seems counter. The fans appear to draw air from the adjacent closed compartment (power supply area) into the motherboard and GPU area. I think Lian Li, has officially run out of ideas.
The fans are shown doing the opposite of what you said.
All this case is, at least from what I can see is a slightly modified and much more expensive Corsair Air 540.
