ligtning/fire sorc build
G
Guest
Guest
Archived from groups: alt.games.diablo2 (More info?)
looking for a good lightning fire sorc hybrid build
i want to put tals set on this one, and was thinking that maybe i'll
divide that stat points
100 str
90 dex <--- i want to use a Lidless Wall for her so whatever to get
max block
? VIT <--- minimal, because i was gonna use energy sheild
? ENG <-- As much as i can spare to put into it
On Fri, 10 Dec 2004 17:18:55 GMT, z123 <z123@z123.org> wrote:
well less block isnt' a primary concern really, i just want to figure
out a good skill point distro for the sorc
using the fire and lightning skill trees
> max block
that won't work out. let's say your lidless has 45% block. the 90 dex will
give full block until lvl 22.
at lvl70 your block will be 24%, the required amount of dex will be 249 😉
it's easier using a mosars or a whitstans, or being happy about less block.
Stefan
"Stefan Roth" <dev@null.net> wrote in message
news:1102701590.689576@nbgm66x...
>> max block
> block.
> Stefan
upped visceraut is best for a sorc that wants skills and max block (72%)
peace,
kyle
