Question Limited internet problem
Apr 3, 2020
Sometime in the past couple of months my computer started acting weird with my home network. I connect and internet works fine then some uncertain amount of minutes after I get limited internet. It stops working, I'm still connected to the network and I can use my phone and any other device in the house to surf the internet just not my pc. To solve the issue I have to disconnect and reconnect from the internet. Troubleshooting instead of reconnecting tells me to reinitialize the built-in wifi adapter which then tells me I have to restart the machine entirely and the wifi stops working until I do so. Not sure what the problem is.
My pc is a Lenovo L340.
Wireless driver is Intel(R) Wireless-AC 9462.
PS: I noticed that on my university network this problem doesn't occur. However, when visiting my brother's house, the exact same issue happened. Would appreciate any help. Thank you.
Namaste🙏 Moudhaffer,
I was facing this very issue for a long long time my computer would connect with some Wi-Fi Connections but used to show limited with the majority of them the solution that worked for me was this video.
View: https://youtu.be/vJtwEXVOZbI
And if it still shows limited access I would highly recommend you to buy a USB WiFi adapter such as this one ;these adapters are cheap and would surely fix your issue
https://www.amazon.in/Terabyte-500M...&pf_rd_p=e36c8f8e-24d2-5f1e-9ffb-9425712e038a
Wishing you good health
Regards,
7vik
