Linear Mechanical Switches vs. Rubber Dome
hnrqbarcelos
Commendable
Aug 10, 2016
4
So, I tried for a little while a MX Red keyboard and the only difference that I felt from a high quality rubber dome keyboard was the "spring" feeling. So I was wondering, since there's no feedback, nor tactile nor audible, in linear mechanical switches, what's the differentiator between the two?
You pretty much listed it.
Rubber dome keyboards just have a little connection that is completed, Linear switches have an actual switch that clicks over.
If you want a real difference, try browns.
