linksys wireless router problem
G
Guest
Guest
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have a linksys wireless router connected to a cable modem. When I connect a PC equipped with Windows XP home addition using an ethernet cable, I can reach the internet.
When I disconnect my ethernet cable and install a PCMCIA (Proxim) wireless card or an external USB (D-Link DWL-122) wireless USB adapter I cannot reach the internet. I have WEP turned off, I do obtain a valid IP address using DHCP and do not have any MAC filtering turned on.
Any help is appreciated.
Chuck
1,479
On Sat, 24 Apr 2004 20:31:06 -0700, johnbu <anonymous@discussions.microsoft.com>
John,
Do the D-Link or Proxim drivers provide any diagnostic?
Please provide ipconfig information for the computer, with the ethernet cable
and then with a wireless device enabled.
Start - Run - "cmd". Type "ipconfig /all >c:\ipconfig.txt" into the command
window - Open c:\ipconfig.txt in Notepad, copy and paste into your next post.
Please provide static route tables for the computer, with the ethernet cable and
Start - Run - "cmd". Type "route print >c:\route.txt" into the command window -
Open c:\route.txt in Notepad, copy and paste into your next post.
With the wireless device enabled:
1) Ping www.yahoo.com.
2) Ping 66.94.230.33.
Report error messages.
Cheers,
Chuck
Paranoia comes from experience - and is not necessarily a bad thing.
G
Guest
Guest
Chuck thanks for your reply. Here is the info you requested:
Route Info
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 b0 d0 51 7c d5 ...... 3Com 3C920 Integrated Fast Ethernet Controller (3C905C-TX Compatible) - Packet Scheduler Miniport
0x30003 ...00 20 a6 4f f1 9c ...... ORiNOCO 802.11ag ComboCard Gold - Packet Scheduler Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.100 30
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.110 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.0.0 255.255.255.0 192.168.0.100 192.168.0.100 30
192.168.0.0 255.255.255.0 192.168.0.110 192.168.0.110 20
192.168.0.100 255.255.255.255 127.0.0.1 127.0.0.1 30
192.168.0.110 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.0.255 255.255.255.255 192.168.0.100 192.168.0.100 30
192.168.0.255 255.255.255.255 192.168.0.110 192.168.0.110 20
224.0.0.0 240.0.0.0 192.168.0.100 192.168.0.100 30
224.0.0.0 240.0.0.0 192.168.0.110 192.168.0.110 20
255.255.255.255 255.255.255.255 192.168.0.100 192.168.0.100 1
255.255.255.255 255.255.255.255 192.168.0.110 192.168.0.110 1
Default Gateway: 192.168.0.1
Persistent Routes:
None
IPCONFIG INFO
Windows IP Configuration
Host Name . . . . . . . . . . . . : TestLaptop
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : 3Com 3C920 Integrated Fast Ethernet Controller (3C905C-TX Compatible)
Physical Address. . . . . . . . . : 00-B0-D0-51-7C-D5
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.0.110
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
Lease Obtained. . . . . . . . . . : Sunday, April 25, 2004 10:28:48 AM
Lease Expires . . . . . . . . . . : Saturday, May 01, 2004 7:08:13 PM
Ethernet adapter Wireless Network Connection:
Description . . . . . . . . . . . : ORiNOCO 802.11ag ComboCard Gold
Physical Address. . . . . . . . . : 00-20-A6-4F-F1-9C
IP Address. . . . . . . . . . . . : 192.168.0.100
Lease Obtained. . . . . . . . . . : Tuesday, April 27, 2004 7:47:35 PM
Lease Expires . . . . . . . . . . : Saturday, May 01, 2004 7:17:06 PM
PING INFO
ping yahoo.com request timed out
ping 66.94.230.33 destination host unreachable
Chuck
1,479
On Tue, 27 Apr 2004 18:06:06 -0700, johnbu <anonymous@discussions.microsoft.com>
John,
Right now, you have 2 network devices defined - a 3Com wired card, and an
Orinoco wireless card. Did you try connecting with the Orinoco?
Please describe how you install and activate the D-Link or the Proxim. What
devices are currently listed in Device Manager - Network adapters?
Can you connect to the router, and look at the DHCP address assignment table?
Cheers,
Chuck
