Liquid closed loop cpu cooler
According to this image,
the only compatible mounting location for a CLC in your inquired chassis is at the read of the case and the maximum size for a radiator would be 120mm. That would include the Seidon 120v2, Nepton 120 xl, Corsair H50/55/60/75/80/80i...and so forth(i.e CLC's based on a single 120mm rad design).
It may be a good idea to stick with air cooling when in the Zalman or go for a case that supports larger CLC's in them.
