liquid cooler for 9590
Dankdab
329
is this a good cooler for the amd 9590?https://www.amazon.ca/Cooler-Master-Seidon-120V-All/dp/B00FFCB0BG/ref=sr_1_1?ie=UTF8&qid=1482983917&sr=8-1&keywords=cooler+master+120mm+fan+liquid Cooler Master Seidon 120V - PC CPU Liquid Water Cooling System, All-In-One Kit with Compact 120mm Radiator and Fan. Also what kind of power supply should I get with this paired with a gtx 960 2gb ssc?
The FX-950 has a few special requirements. The Seidon 120V AIO water cooler is insufficient for anything above stock frequency at 4.7GHz.
You should have a min 850W gold certified PSU and a MB that fully supports the 220W TDP draw that the CPU has.
As said, you would be better to wait for Ryzen to be released. The FX-9590 is a beast of a processor but it can be tamed with The above requirements.
