T tlew20 Jan 13, 2019 12 0 10 Jan 14, 2019 #1 So I recently got a Corsair H45 liquid cooler, and it's started making a rattling noise which is pretty consistent, sometimes it disappears for a couple seconds or minutes then comes back. Is this normal or is there a fault? Thanks
Solution C C Crosslhs82x2 Jan 14, 2019 Did you buy it new? If so get a hold of cosair tech support sound like faulty pump.
C Crosslhs82x2 Splendid Aug 12, 2017 2,117 379 27,840 Jan 14, 2019 Solution #2 Did you buy it new? If so get a hold of cosair tech support sound like faulty pump. Upvote 0 Downvote Solution
N neohanger Commendable Nov 29, 2018 20 0 1,510 Jan 18, 2019 #3 i would check all screws are tight and maybe its just a noisy fan. check some youtube videos reviewing it and see if they have the same noise problem Upvote 0 Downvote
