Liquid Cooling a PC
Larry_The_Great
41
Dear Toms Hardware Forum
Here are the parts for my current PC.
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler
Motherboard: Gigabyte GA-Z87X-UD5H ATX LGA1150 Motherboard
Memory: Corsair Vengeance LP 16GB (2 x 8GB) DDR3-1600 Memory
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 760 2GB Dual Superclocked ACX Video Card
Case: Phanteks Enthoo Series Primo Aluminum ATX Full Tower Case
Power Supply: Silverstone Strider Gold S 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter
I now want to water cool my PC and was looking for some help. My aim is to make a cool looking custom watercooling loop through my PC (to be completely honest I am mainly water cooling for looks not for the performance) that cools the CPU and graphics card for a price around $500. My first problem is I don't think my GPU is compatible with any water blocks. I know you can custom cool the voltage and that stuff to make it work but I'd rather have a block that cooled the entire gpu without any hastle. So firstly...
1. Should I buy a new GPU for watercooling? If so Which one and what water block? Or what other options do I have?
I haven't decided on the other parts of the watercooling, I am aware of all the parts I need but am unsure which ones would best suit me. I want acrylic tubing and I am prepared to bend it myself as I believe that looks the best. For radiators and that should I go conservative considering my cpu and gpu aren't that intensive? But then again I don't really want to have to upgrade my watercooling loop once I upgrade my parts. So secondly...
2. Can someone please recommend what parts I should use for the rest of the watercooling loop.
I am open to all options regarding the parts and gpu although I would like to try and aim for $500 as I said before or if that's not possible maybe a bit over. Thank you to anyone who has taken the time to read and reply to my post I really appreciate it!
Ok your budget is actually kind of tight for doing a full loop... CPU chip is going to be 100-150, Full cover GPU is 150 again, RAD is going to be around 100+, Pump and Res Combo another 100+ and then fittings at 10 per (these costs add quick), plus tubing, so prices add up fast. For checking GPU's I generally use EK's website (its just there stuff but they cover all the normal PCB's and some of the custom ones, didnt see yours there unfortunately)
http://www.coolingconfigurator.com/
For any loop a quick estimate is 120mm fan per 100W of heat, so for a normal 1 CPU and 1 GPU would be ~100W+200W for a triple RAD
A small piece of advise is to include a drain port (i do mine with a T adapter and ball valve, doesnt look as clean but very...
A small piece of advise is to include a drain port (i do mine with a T adapter and ball valve, doesnt look as clean but very handy)
As mentioned you don't NEED a water loop for your setup, that said most of us don't need as powerful of computers as we have so not judging on that lol.
