[SOLVED] Liquid cooling CPU & GPU
Jan 6, 2019
5
Hello,
I’ve been looking for a liquid cooling kit that is compatible with my CPU and GPU. Any recommendations? It does not have to be a kit but from what I heared that some of the kits should be compatible with my specs.
CPU: Ryzen 5 2600
GPU: AMD RX 580 4GB
Motherboard: ASUS Prime 350 M-A
I’ve been thinking of OC and from what I researched Liquid cooling is the best option.
Thank you!
Are you looking for a custom liquid cooling loop or an AIO solution? If custom level, please read the watercooling sticky(in my sig) and decide if watercooling is for you. To also break a notion, no, liquid cooling isn't always the best solution since you will need to consider other factors when dealing with (heating&)cooling.
