Alright everyone I acknowledge I probably have lost my mind. I'm something of a nostalgic person and my very first computer IBM PS/2 Model 50 with 286 chip. I don't know many people actually remember that particular model but I have always loved it. So anyways I thought it fitting since I'm building my first gaming rig that it be in a similar case and I found this on newegg and couldn't help myself. I plan on liquid cooling this and had a few questions.
Here is my design:
http://pcpartpicker.com/user/jklein11/saved/1vxs
1. Is it possible with the setup I have?
2. This may sound stupid but is a single 120mm Raditor going to fit a dual 60mm fan fan exhaust vent and the corresponding screw holes? (I'm pretty sure it will but I want to be positive.)
3. Is the 80mm intake fan I choose a decent fan?
4. due to the fact I have just that 80mm fan for air flow should I consider getting a cooling block for my memory and HDD also.
5. If I do need to liquid cool the memory and hdd should I forget about the 80mm fan and just put a single 80mm radiator in its place?
6. Do I have all the parts I need for my system if I dont need to liquid cool my hdd and memory.
7. Since I'm going to be pushing my memory to the full 2100 mhz should I be liquid cooling anyway?
8. Since I'm going to be pushing this cpu as far as I can go speed wise should I spend the extra few bucks for an FX 8350 due to the fact it has a higher stock speed and the limited airflow in my case?
Here is my design:
