liquid cooling on spec 01 ?
The radiator can be mounted in the front BUT the tubes are not long enough to allow to the block to be mounted on the cpu. So NO it will not fit. You can use any of those suggested by corsair. Besides there is not noticeable difference between a 120mm and a 140mm radiator.
