T tsxfire Honorable Sep 20, 2013 35 0 10,540 Mar 20, 2014 #1 I am getting an 8350 and was curious what cpu cooler type i should get im looking for something that doesnt cost more than 130 and what will be best for getting good overclock
Solution CM-Patrick Mar 20, 2014 Dear tsxfire, I would suggest looking at our Glacer 240L. This cooler is expandable so you can add extra radiators or a GPU water block in the future. Glacer 240L
Drew010 Honorable May 11, 2013 1,150 0 11,660 Mar 20, 2014 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16835181035 is your best bet for keeping it cool Upvote 0 Downvote
T tsxfire Honorable Sep 20, 2013 35 0 10,540 Mar 20, 2014 #3 also im using the HAF XB EVO for a case and intend to have a 10in card Upvote 0 Downvote
Drew010 Honorable May 11, 2013 1,150 0 11,660 Mar 20, 2014 #4 tsxfire : also im using the HAF XB EVO for a case and intend to have a 10in card Then http://www.newegg.com/Product/Product.aspx?Item=N82E16835181060 will be the best Upvote 0 Downvote
CM-Patrick Honorable Oct 31, 2013 238 0 10,860 Mar 20, 2014 Solution #5 Dear tsxfire, I would suggest looking at our Glacer 240L. This cooler is expandable so you can add extra radiators or a GPU water block in the future. Glacer 240L Upvote 0 Downvote Solution
T tsxfire Honorable Sep 20, 2013 35 0 10,540 Mar 20, 2014 #6 thanks patrick that looks like it would be perfect and it heeps my whole system as Cooler Master which is kinda nice Upvote 0 Downvote
CM-Patrick Honorable Oct 31, 2013 238 0 10,860 Mar 20, 2014 #7 Great Please let me know if you have any more questions Upvote 0 Downvote
