I just saw an announcement that Thermaltake is making an affordable option that does not use water cooling but yet efficient that they said run a cpu at 38 degrees and run a freon compressor, which is said to be released in the next couple months. The representative indicated that it will not cause any condensation and the compressor is warranted for 10 years backed by the manufacture and expected to cost $200.
What are you thoughts on this, or if you got more information about this explain away. I am curious to know more about this solution, and to know if this can be better. I know personally this sounds good that I don't have to worry about changing the water, and sounds reasonably low cost saving solution.
