[SOLVED] Liquid cooling power?
jaaprikm
34
Heyo,
I was thinking about installing myself a coolermaster 120 lite. But im not sure were all the cables go. I think the fan of the cooling system goes in cpu_fan1. But where does the plug for the pump go (the thing mounted on the cpu). I am a really big amateur at this subject :)
Thanks in advance!
jaaprikm
34
Allright thanks, just came to the conclusion my mobo does not have the PUMP_FAN1 header. Is it possible to put the pump in the CPU_1 fan and put the fan in another fan header? For example I have a spare 4 pin SYS_FAN. Could I plug the pump header in there?
