Liquid cooling pump connection
ibanman555
21
I've a Corsair H60 cooler for my processor, been running this way for a while. I connected the fan to the "CPU fan" connection on the motherboard and the pump to the "Rear Fan". My CPU temp lately is 65-80°C. It got up to 91°C after running memtest+86 last night. The return tube is pretty warm to the touch, and send tube is cool. That tells me it's at least cycling liquid.
If I connect the pump directly to the PSU instead of the rear fan, would I get a more consistent cycle of liquid. Is this safe?
The Noctua NH-D14 keeps my CPU under 50C during stress... I don't think 70C is safe for any CPU to stay at for long amounts of time. Only the GPU should be able to tolerate 80C+...
-Bloc97
Ok I seriously didn't know that. So a Intel CPU on stock cooling is fine if it reaches 90C under load?
Nevermind what I said about hooking to the PSU. I was wrong there. However I did swap connections as stated above because they were wrong. Hopefully it cools down a little better...
