liquid cooling questions
chucky9
548
5
19,015
i have two questions, so my situation my h80i stopped working properly after i tried to move it around and now only one power cable to fans works(both fans still work fine) and neither the fan nor the pump will now show up in link so.
1 should i try getting new cables and see if tht works which at £9.99
2 cos my case is actually to small for it so i had to put one fan on the outside, is there a version of the h60 with the thin rad 2 fans and a square pump.
thnx for help
The CFM isn't as high as some of the higher end fans but they still aren't anything to sneeze at. Yeah I would definitely check the cables first then try out the fans. If you don't like em, sell em on ebay.
