Hey, if anyone can give me some helpfull feedback on this- much appreciated!
I'm working on a custom liquid cooling system so I can start overclocking, and I just bought a Swiftech QP 2x120mm Radiator/Reservoir.
I attatched it to the back of my case as you can see in the pics. The only concern I have is that the top part, were the built in reservoir is is mounted somewhat in front of the P/S exhaust fan.
Is this a problem really or not? Its a 680W supply, but doesnt seem like a big affect to me.
Also whats the difference btween placing the pump before the radiator (as in pushing water through it) or after the radiator (as in sucking water from it)? All I have read is that it is beneficial to place it before because you want the coolest water (coming directly from the radiator) going to the components. However how much heat could a 12VDC pump actually add to the coolant that it is moving at such a swift pace?
Here are some more pics of my system. So far I was thinking just of cooling the CPU, ATI Card, and the NB/SB. I was thinking about cooling the HDDs but the affects (appx 3C) just doesnt seem worth it.
Anyways, thanks.
Anyways, thanks.
