A azx151 Reputable Jun 1, 2015 71 0 4,630 Jun 8, 2015 #1 My cousin says: what kind of liquid cooling system is compatible to the radeon HD 7770? Do any of you know? can you answer please? can you leave a LINK please? thanks
Solution Gam3r01 Jun 8, 2015 I dont recommend you attempt to water cool the 7770, that is a waste of money. Not even the Kraken G10 works on the card. For the cost of the components you would be better off getting a new card.
Gam3r01 Titan Jan 12, 2013 25,414 974 115,440 Jun 8, 2015 Solution #2 I dont recommend you attempt to water cool the 7770, that is a waste of money. Not even the Kraken G10 works on the card. For the cost of the components you would be better off getting a new card. Upvote 0 Downvote Solution
