Hey all. I currently am running an air cooled setup, and have been for quite a while. I did a bit of research on water cooling, and would like to make a future upgrade. What I am looking for is a kit to install, since I do not have sufficient knowledge to piece a system together myself.
Running with an ATX Mid-Tower right now. I like the concept of Coolermaster's Aquagate Max, but unfortunately the dual 120mm radiator will not work with my case. Is there anything worth getting that is like the Aquagate that only has a single 120mm radiator? Or will a single not provide much cooling ability?
I would also replace the stock waterblock with something a bit better (D-Tek), as the Coolermaster stock is pretty primitive.
Thanks
P.S. Looking to mount pump/reservoir in empty 5.25" bays.
Thanks
