Hi, I had a question regarding the type of 120mm fans that should be used with a liquid cooling system. A couple years back, I purchased a Corsair H100i liquid CPU Cooler, and I was told that it was important to use Static Pressure (SP) fans, and I did purchase two Corsair Static Pressure (SP), which worked very well for me over the years, and they were very quiet too.
Fast forward to now and I’m again buying another Corsair H100i 240mm, which is much more powerful than my unit from five years ago. However, I noticed that Corsair Liquid Cooling System now comes with two Magnetic Levitation (ML) 120mm fans instead of a fans from their current line of Static Pressure fans.
I will add that I already have one Corsair Magnetic Levitation (ML) 120mm fan that I purchased two years ago as an exhaust fan in the back of my build, which is quiet too.
I was wondering if anyone knew why Corsair had switched from Static Pressure (SP) 120mm fans to the Magnetic Levitation (ML) fans?
I assume that the Magnetic Levitation (ML) fans are superior because they basically float or levitate inside the fan cage, and so they do not produce friction or anything that would make unwanted sound. So that sounds like a good reason to switch fans; however, do not SP fans provide something unique to their design that helps cool the radiator than other types of one do not offer?
If anyone has an good answer to my question, I would be thankful if you provided it. Thanks.
