Hi recently installed a Thermaltake 3.0 Pro Water Cooler mounted to the inside back of my Thermaltake Chaser A71 Full Tower Case and found much to my dismay that I was Unable to fully close the sliding Side panel cover due to It hitting the fitted 200mm Blue Led Fan mountings. The Radiator hoses in this case were from the bottom nearest the video card pcie X16 slot which to my understanding is the way it should be.
However in my case I had to flip it upside down in order to just close this side panel without too much bother, as the hose end of the radiator is usually a bit more bulkier owing to the inbuilt water reservoir of this unit.
My question here is would the fact that the hoses coming from the top end of this mounted radiator be :
(a) Stress on my 3.0 water block cpu pump since it is working against gravity.
or (b) No burden on it at all since it is a closed sealed Unit.
I would appreciate any feedback at all on this subject as I know a lot of this stuff would be on the minds of many others out there.
Concerned Les.
Concerned Les.
