Alright, what follows is a relatively detailed description of what I'm dealing with at the moment. If you'd like to skip the details because you think they're unnecessary, jump to the tl;dr below. Thank you either way.
Built my computer about a year and a half ago.
Keep it in relatively warm house running most of the day for the past year. House is kept at around 78-80˚F at all times, sometimes warmer. No heating issues ever. My last computer (totally different setup) never had any issues either with temperature. I move to a new city, post up in an apartment. Room is bigger by a decent amount and this time my computer is literally out in the open standing on stable, thick plywood. I have no ventilation downward save the power supply. The only two fans I have are an intake in the front and an exhaust in the back. Both came with the case. Also fan for GPU and CPU obviously. Both are factory OEM. Runs great and fine for a good long while. Leave it on almost 24/7 because of updates and the unnerving wait of having to let all my startup programs load at boot.
Jump to about 3 or 4 months ago, I noticed the CPU fan having to work extra hard but I didn't think much of it because the games I was playing were getting more demanding on the hardware so I just thought it was a natural need for the fan to keep up with the heat. About 2 months (maybe more) ago, my computer shuts down as if it was a hard shutoff. Totally freaked me out, had no clue what caused it. Thought it was a power fluke. Started investigating but it didn't happen again even after I played whatever game it was at high load. Eventually forgot about it and let the computer keep running.
About 3 weeks to a month ago, starts shutting down like that again almost daily. Eventually narrow it down to an overheating issue considering HWmonitor is showing temps as high as 85˚ C coming from my CPU exclusively. Feel the backplate of my case and I swear could almost cook an egg on it.
I look around and someone said something about resetting CMOS. I do that and have some ram troubles but I fixed those (I'm fairly certain). RainbowSix Siege Alpha comes out, play it totally fine on my desktop then bam, overheats again. This time at 80˚C. Overheats once more playing Alpha at about 82˚. Mind you I've always kept the apartment at least 73˚F. GTA comes out and the overheating gets nasty. Had it overheat about 3 times since GTA's release. About time I need a cooler but I have a couple questions first...
1. Is my CPU f'ed already?
2. Is my CPU socket f'ed already?
3. Last but not least, the most important question: Obviously in need of a new CPU cooling solution. Case is small but I hear very mixed reports of my case being able to do liquid CPU cooling considering the ceiling on the case is about less than an inch high from top of MOBO. Some people say they need to make minor case mods, some say it fits right in. Estimated measurements show I could incorporate an H60 comfortably but the ceiling is the only area of concern. Should I take the jump and order the cooler and if it doesn't fit try a case mod or return it? If I do return it or I shouldn't take the jump, what is the absolute best suggestion for an air-based CPU cooler for an AMD FX-8350? Price is not a huge concern. My ceiling is about $100.
I just need this fixed asap. I keep trying to find ways to manually lower my temps by either pausing the game or just running on low settings but it's always when I get too involved and forget to monitor my temps that my unit overheats. Anyone wanna help a brother out??
tl;dr: CPU may be f'ed, need cooler in case it isn't, some say liquid cooling will work others say it won't in my case. Anyone know if an H60 could naturally fit in a Thermaltake Commander MS-I without need for extra holes or mods? I've seen pictures showing natural fits and I've seen pictures showing the need for the unit to be placed outside of the case because the rad height is too tall to be properly screwed into the case. If not, what's the best air-based CPU cooler money can buy that will make sure this thing doesn't breach 65˚?
