Hello, i would like to know what to look for when trying to figure out whether a liquid refrigeration would fit in my computer or not. I already know the most basic thing which si the socket. My socket is 1155 (my mobo is asus p8h67-m pro).
The refrigeration that i want to buy is compatible with socket 1155. But i am worried about the space and the connections. Concerning about the space, i don't really know what to measure to tell if i have enough space (i don't currentyl have any chasis fan) i would need some info on this topic.
And the other thing, the connections:
Liquid refrigeration model: Enermax Liqmax II 120S
my PSU model: Nox urano vx 750
The refrigeration has 3 cables to be connected. The first needs to be plugged in the cpu fan connector. And the other two cables have to be connected into an adapter which comes with the pack. And this adapter to the chasis fan connector.
But the thing is, my chassis fan connector is slightly bent, and i don't expect it to work. But, the cables of the two fans can also be pluged in the psu, if it has free cables, am i right?
as you can see, i have lots of doubts. I'd like you to put a bit of light on the topic for me, thanks.
sorry for this english.
