Folks - seeing some weird numbers.
First question - what should I use against the jtmax for my Q9300 - cpu temp or core temp? What about intel's published tjmax for my chip - 71.4C - is that core or cpu temp?
Next- I just instllaed a swiftech h20-220 liquid cooling for the cpu (currently running prime on it as I type) - the weirdness comes in those temps I mentioned. I had a xigmatek s1283 prior - and below are the temps before and now:
CURRENT OC SETUP
vcore 1.304 (droop to 1.28)
fsb 494
multi 7.5
Ambient Temp 27C
XIGMATEK TEMPS
CPU - idle 30c
CPU - load 50c
Core - idle 44c (hottest of all 4 cores - core1)
Core - load 70c
Swiftech H20 - 220 Liquid
CPU - idle 29c
CPU - load 44c
Core - idle 44c
Core - load - 63c
Using stock liquid that came with the system. Using stock Apogee cpu block with built in pump.
Could I see better temps if I add a reservoir and used a dedicated pump with dedicated cpu block?
Am I doing something wrong? I've read a lot of reviews for this swiftech h20-220 system with 10c reduction in temps for their tests - but mine is not that much improved!
Thanks.
CURRENT OC SETUP
fsb 494
multi 7.5
Ambient Temp 27C
XIGMATEK TEMPS
CPU - idle 30c
CPU - load 50c
Core - load 70c
CPU - idle 29c
CPU - load 44c
Core - idle 44c
Core - load - 63c
Thanks.
